Disables the restart helper router from terminating graceful OSPF restart when received LSAs would affect the restarting router.
| all | Specifies all VLANs. |
| vlan-name | Specifies a VLAN name. |
| router-identifier | Specifies the router ID of the remote router of the virtual link. |
| area-identifier | Specifies an OSPF area. |
The default is enabled.
This command disables the restart helper router from terminating graceful OSPF restart when received LSAs would affect the restarting router.
The following command disables a router from terminating graceful OSPF restart for all routers in area 10.20.30.40 if it receives an LSA that would affect routing:
disable ospf area 10.20.30.40 restart-helper-lsa-check
This command was first available in ExtremeXOS 11.3.
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
